title: "PostgreSQL integration | Grafana Labs"
description: "Monitoring PostgreSQL databases"
# PostgreSQL integration
The PostgreSQL integration monitors connections, replication, cache, locks, and table metrics. The integration reference calls this infrastructure-level observability. For query-level detail (slow queries, wait events, and execution plans), use [Database Observability](/docs/grafana-cloud/monitor-applications/database-observability/).
| **What it’s for**  | Monitoring queries, connections, replication, and vacuum/bloat health        |
| **Under the hood** | Uses the PostgreSQL exporter (`prometheus.exporter.postgres`) and scrapes it |
## Metrics collected
The integration collects these PostgreSQL metric groups:
- **Queries**: Active, waiting, and duration. Waiting queries usually point to lock contention.
- **Connections**: Used, available, and by state, including how close you are to `max_connections`.
- **Transactions**: Commits, rollbacks, conflicts
- **Replication**: Lag and slot status, which show whether a standby is ready for failover.
- **Vacuum**: Dead tuples and autovacuum. PostgreSQL keeps old row versions until vacuum removes them, and the dashboards track that buildup.
## What to know
This integration offers:
- Prebuilt dashboards: PostgreSQL cluster overview, PostgreSQL instance overview, PostgreSQL logs, PostgreSQL query performance
- Prebuilt alerts: connections, replication, vacuum
- Buffer cache hit ratio
- Query waiting and lock detection
## Set it up
Open this path in your Grafana Cloud stack for a fully interactive experience, or read through it to understand the process first.
Learning path
#### Monitor PostgreSQL with Grafana Alloy
Welcome to the Grafana learning path that shows you how to monitor PostgreSQL databases with Grafana Alloy and use pre-built dashboards and alerts in Grafana Cloud.
18 min
Beginner
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud]()
[View on website](/docs/learning-paths/postgresql-integration/)
