title: "MySQL integration | Grafana Labs"
description: "Monitoring MySQL databases"
# MySQL integration
The MySQL integration provides **database performance monitoring** for MySQL instances, whether standalone, replicated, or clustered. Running out of connections is a classic MySQL failure, and the InnoDB buffer pool hit ratio reveals whether your working set still fits in memory.
| **What it’s for**  | Monitoring query performance, connections, replication, and InnoDB health |
| **Under the hood** | Uses the mysqld exporter to read server status and InnoDB metrics         |
## Metrics collected
The integration collects these MySQL metric groups:
- **Queries**: QPS, slow queries, query types
- **Connections**: Active, max, threads
- **InnoDB**: Buffer pool, I/O, row operations
- **Replication**: Lag, status, errors
## What to know
This integration offers:
- Prebuilt dashboards: MySQL, MySQL logs
- Prebuilt alerts: replication lag, slow queries, instance down
- Query performance and slow query visibility
- InnoDB buffer pool and I/O metrics
## Set it up
Open this path in your Grafana Cloud stack for a fully interactive experience, or read through it to understand the process first.
Learning path
#### Monitor MySQL with Grafana Alloy
Welcome to the Grafana learning path that shows you how to monitor MySQL databases with Grafana Alloy and use pre-built dashboards and alerts in Grafana Cloud.
16 min
Beginner
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud]()
[View on website](/docs/learning-paths/mysql-integration/)
