title: "Prerequisites for deploying an integration | Grafana Labs"
description: "What you need to complete the hands-on sections"
## For hands-on practice
If you’d like to follow along with the learning path exercises and deploy integrations on real systems, you’ll need:
- A Grafana Cloud account ([sign up free](/signup/cloud/connect-account))
- A system to monitor (Linux, Windows, database, etc.)
- Permissions to install Grafana Alloy on your target system
**Just exploring?** You can complete the course without hands-on practice. The concepts and decision frameworks are valuable on their own.
## Recommended prior knowledge
| Topic                                | Why it helps                       |
| Basic Grafana navigation             | You’ll use pre-built dashboards    |
| Terminal/command line basics         | Agent installation uses CLI        |
| Understanding of your infrastructure | Helps choose the right integration |
