title: "Operations at Level 3 | Grafana Labs"
description: "Alerting, SLOs, and investigation for transactions"
## Transaction-level operations
At Level 3, alerting works at the **aggregate level** — percentiles, error rates, and SLOs. Traces are for investigation after an alert fires, not the source of the alert itself.
### Alerting
| What to alert on    | Example                                                  |
| Latency percentiles | P99 latency &gt; 2s for payment flow across all users    |
| Span error rates    | Database span error rate &gt; threshold                  |
| SLO burn rate       | Critical path success rate burning error budget too fast |
### SLOs
| SLO type              | Example                                     |
| Transaction success   | 99% of checkout flows complete successfully |
| Critical path latency | 95% of payment transactions &lt; 1s         |
| End-to-end latency    | 90% of user journeys &lt; 3s total          |
### Dashboards
| Dashboard type       | What you see                                |
| Trace analysis       | Span breakdown, latency distribution        |
| Flame graphs         | Where code spends time (profiling)          |
| Frontend performance | Core Web Vitals, user experience metrics    |
| AI/LLM metrics       | Token usage, model latency, prompt analysis |
### Investigation
| Tool                  | How you use it at Level 3                    |
| **Trace Explorer**    | Search traces by attributes, find slow spans |
| **Trace-to-logs**     | Jump from trace span to related logs         |
| **Trace-to-profiles** | See code-level performance for a trace       |
| **Session replay**    | Watch what the user actually experienced     |
**At Level 4, you’ll alert on custom metrics and KPIs.**
