title: "Resources and next steps | Grafana Labs"
description: "Resources and next steps for using Grafana Assistant"
## Continue with Grafana Assistant
Use these topics to build on the Assistant workflows covered in this guide.
| Topic                     | Description        | Where to start        |
| **Learn mode**            | Get guided observability lessons tailored to your role and environment.      | [Use Learn mode](/docs/grafana-cloud/machine-learning/assistant/guides/learn-mode/)                       |
| **Alerting**              | Use Assistant to create and manage alerting rules.                           | [Alerting with Assistant](/docs/grafana-cloud/machine-learning/assistant/guides/alerting/)                |
| **Infrastructure memory** | Automatically build context about your services to speed up troubleshooting. | [Use infrastructure memory](/docs/grafana-cloud/machine-learning/assistant/guides/infrastructure-memory/) |
| **Slack**                 | Use Assistant from Slack without opening Grafana.                            | [Slack](/docs/grafana-cloud/machine-learning/assistant/guides/slack/)                                     |
| **Extend with SDKs**      | Integrate Assistant into plugins and external applications.                  | [TypeScript SDK](/docs/grafana-cloud/machine-learning/assistant/reference/typescript-sdk/)                |
## Read documentation
Refer to these docs for setup, configuration, and product details.
- [Grafana Assistant](/docs/grafana-cloud/machine-learning/assistant/)
- [Manage your data privacy and security](/docs/grafana-cloud/machine-learning/assistant/privacy-and-security/)
- [Configure Grafana Assistant](/docs/grafana-cloud/machine-learning/assistant/configure/)
- [All Assistant guides](/docs/grafana-cloud/machine-learning/assistant/guides/)
## Join the community
Use these community resources to ask questions and learn how other teams use Grafana.
- [Grafana Community Forums](https://community.grafana.com/)
- [Grafana Slack](https://slack.grafana.com/)
- [Grafana on GitHub](https://github.com/grafana/grafana)
