title: "Key takeaways | Grafana Labs"
description: "Summary of what you learned"
## What you learned
1. **Fleet Management = Central control** for all your collectors
2. **Collectors register** with `remotecfg` block and appear in inventory
3. **Configuration pipelines** remotely configure without touching machines
4. **Attribute matching** targets pipelines to specific collector groups
5. **Local + remote configs** run in parallel, isolated from each other
6. **Force multiplier** for Level 1 that makes existing capabilities scale
## The core workflow
[Fleet Management workflow: Register, Monitor, Create, Assign, Repeat](fleet-management-workflow.svg "Fleet Management workflow: Register, Monitor, Create, Assign, Repeat")
## What to do next
- **Expand your fleet** — Register more collectors as you deploy them
- **Create pipelines** — Build configs for your specific monitoring needs
- **Refine attributes** — Adjust your schema as patterns emerge
- **Explore dashboards** — Use health data to catch issues early
