title: "Why it's safe to experiment | Grafana Labs"
description: "Understanding Fleet Management's safeguards"
## Safeguards
Fleet Management is designed with safety in mind.
[Experiment with confidence](fleet-management-safeguards.svg "Experiment with confidence")
## Four safeguards
| Safeguard            | What it means                              | Why it matters                             |
| **Isolation**        | Local and remote configs run independently | Remote errors don’t break local collection |
| **Fallback**         | Invalid configs aren’t applied             | Bad syntax doesn’t stop your collector     |
| **Instant rollback** | Deactivate pipelines with one click        | Fast recovery from any problem             |
| **Targeted testing** | Use matchers to limit blast radius         | Test on one collector before fleet-wide    |
## What happens when things go wrong
| Scenario                      | What Alloy does                                   | Your action                           |
| **Syntax error in pipeline**  | Rejects config, keeps last known good             | Fix syntax, re-save pipeline          |
| **Pipeline causes high load** | Runs but collector health dashboards show warning | Deactivate pipeline, investigate      |
| **Wrong collectors matched**  | Pipeline runs on unintended collectors            | Update matchers, deactivate if needed |
