title: "Key takeaways | Grafana Labs"
description: "Summary of what you learned"
## Key takeaways
1. **Fleet Management = Central control** for all your collectors.
2. **Collectors register** with `remotecfg` block and appear in inventory.
3. **Configuration pipelines** remotely configure without touching machines.
4. **Attribute matching** matches pipelines to specific collector groups.
5. **Local + remote configs** run in parallel, isolated from each other, which makes it safe to experiment.
6. **Scales your operations** so managing many collectors takes the same effort as a few.
## The core workflow
[Fleet Management workflow: Register, Monitor, Create, Assign, Repeat](fleet-management-workflow.svg "Fleet Management workflow: Register, Monitor, Create, Assign, Repeat")
