title: "Configuration strategies | Grafana Labs"
description: "Balancing local and remote configuration"
## Configuration strategies
Fleet Management gives you flexibility in how you balance local and remote configuration. You don’t have to go all-in on either approach. Choose the strategy that fits your situation.
[Three strategies for balancing local and remote configuration](fleet-management-strategies.svg "Three strategies for balancing local and remote configuration")
## Remote-first
Minimal local config, everything else managed remotely. Best when a dedicated team manages observability and you want maximum central control over the fleet.
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
remotecfg {
    url = "https://..."
    // ... auth config
    id = constants.hostname
    attributes = {"env" = "prod"}
// Everything else comes from Fleet Management
## Local-first
Primary config stays local, Fleet Management for self-monitoring. Best when your main configuration is already managed through an existing deployment process and you want Fleet Management mainly for collector health.
```alloy
// Local config: full configuration
remotecfg {
    url = "https://..."
// All your standard collection is here
prometheus.scrape "node" { /* ... */ }
prometheus.scrape "app" { /* ... */ }
loki.source.file "logs" { /* ... */ }
// Fleet Management used only for collector self-monitoring
## Hybrid
Top-level config blocks stay local. Everything else is remote. Best when some configuration must stay local but your needs vary by environment, so the rest is easier to manage remotely.
```alloy
// Local config: top-level blocks
logging { level = "info" }
livedebugging { enabled = true }
remotecfg {
    url = "https://..."
// All other config managed remotely in Fleet Management
