title: "Matching in practice | Grafana Labs"
description: "Common patterns and examples for attribute matching"
## Common patterns
Because every collector carries its own attributes, you can organize your fleet along whatever dimensions fit: environment, region, team, service, or even Kubernetes namespace.
| Pattern               | Matcher examples                              |
| **Environment-based** | `env="production"`, `env="staging"`           |
| **Region-based**      | `region="us-east"`, `region="eu-west"`        |
| **Team-based**        | `team="platform"`, `team="backend"`           |
| **Catch-all**         | `collector.os=~".+"` (matches all collectors) |
## Example: Production platform pipeline
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
Matchers: env=~"prod-.*", team="platform"
This pipeline applies to collectors where:
- `env` matches the regex `prod-.*` **AND**
- `team` equals `platform`
## Limits to know
| Limit                          | Value                                       |
| Matcher length                 | 200 characters max (key + operator + value) |
| Local attributes per collector | 22 max when polling                         |
These limits are generous for most use cases, but worth knowing as you design your schema.
