title: "Configuration pipelines | Grafana Labs"
description: "Understanding how to create and manage remote configurations"
## Configuration pipelines
A configuration pipeline is the unit of remote configuration in Fleet Management. It’s configuration to perform one operation, such as monitoring MySQL. You can match multiple pipelines to a single collector and multiple collectors to a single pipeline.
Each pipeline has a name, configuration content, and matching attributes.
[Anatomy of a configuration pipeline](fleet-management-pipeline-anatomy.svg "Anatomy of a configuration pipeline")
## Key terms
| Term                       | What it means        |
| **Remote configuration**   | All the configuration pipelines matched to a collector                                    |
| **Configuration pipeline** | The pieces of config you create and assign, usually representing one monitoring operation |
## Pipeline components
| Component               | Description                                  |
| **Name**                | Unique identifier for the pipeline           |
| **Content**             | Standard configuration for one operation     |
| **Matching attributes** | Rules that assign the pipeline to collectors |
> **Pipelines are reusable.** Create once, assign to many collectors using attribute matching.
