title: "Your observability journey | Grafana Labs"
description: "Where Fleet Management fits in your observability journey"
## Where are you on the observability journey?
[Hierarchy of Observability Needs pyramid showing Level 1 highlighted](https://grafana.com/media/docs/learning-hub/instrumentation-hub-hierarchy-of-needs.png "Hierarchy of Observability Needs pyramid showing Level 1 highlighted")
In the **Hierarchy of Observability Needs**, Level 1 is **Infrastructure Foundation**:
> *“Is my infrastructure healthy?”*
You achieve Level 1 coverage by deploying collectors that gather metrics and logs from your servers, databases, and services.
## Fleet Management as a force multiplier
Fleet Management is a force multiplier because it scales your capacity without scaling your effort.
[Fleet Management expands your Level 1 foundation](fleet-management-force-multiplier.svg "Fleet Management expands your Level 1 foundation")
| Without Fleet Management                      | With Fleet Management                        |
| Scaling collectors = scaling operational work | Scaling collectors = same operational work   |
| Coverage limited by management overhead       | Coverage limited only by your infrastructure |
> Fleet Management removes the operational bottleneck that prevents you from expanding your Level 1 foundation.
