title: "When you might not need it | Grafana Labs"
description: "Situations where Fleet Management adds unnecessary complexity"
## When Fleet Management might not fit
| Signal                           | Why it might not be needed                       |
| **1-5 collectors**               | Manual management is still manageable            |
| **Static configurations**        | Configs rarely change after initial setup        |
| **Distributed ownership**        | Each team owns and operates their own collectors |
| **Identical configs everywhere** | All collectors run the exact same config         |
## It’s OK to wait
Fleet Management scales down gracefully. You can:
- **Start simple** — Manage a few collectors manually
- **Adopt later** — Add Fleet Management when the pain becomes real
- **Try it out** — Register one collector to explore before committing
## Still unsure?
Continue with this course anyway. The hands-on experience will help you evaluate whether Fleet Management fits your needs. You can always register a single collector to try it out.
