title: "How Database Observability works | Grafana Labs"
description: "Architecture and data flow for Database Observability"
# How the data flows
Grafana Alloy runs alongside your database and reads its **built-in statistics**. Where those statistics come from depends on the database:
- **PostgreSQL:** `pg_stat_statements` for aggregate query statistics and `pg_stat_activity` for active sessions. The `pg_stat_statements` extension must be installed and enabled.
- **MySQL:** Performance Schema, which is enabled by default in MySQL 8.0 and later
Alloy splits that data into two streams and forwards each to a different Grafana Cloud backend:
- **Metrics** (query counts, latency, errors, and resource usage) are scraped by database exporters and sent to **Grafana Cloud Metrics**.
- **Logs** (query samples, explain plans, schema details, and wait events) are collected by the Database Observability components and sent to **Grafana Cloud Logs**.
Grafana Cloud provides Database Observability dashboards that bring the metrics and logs together into a single view of query performance, starting with the Queries Overview dashboard.
> Database Observability is designed to minimize impact on your production databases. To capture an explain plan, it runs `EXPLAIN`, not `EXPLAIN ANALYZE`, so the query itself does not run. That has minimal overhead for most queries.
## When you collect more than you need
Query samples, schema details, and wait events are sent to Grafana Cloud Logs along with the metrics. If that is more than you need, [Requirements and overhead](/docs/grafana-cloud/monitor-applications/database-observability/set-up/requirements-overhead/) lists three changes:
- Raise `collect_interval`, for example from 1 minute to 5 minutes.
- Lower `explain_plans.per_collect_ratio`, for example to `0.5` or lower.
- Exclude schemas you don’t need (`exclude_schemas` on MySQL) or databases you don’t need (`exclude_databases` on PostgreSQL).
[Tune Alloy collection](/docs/grafana-cloud/monitor-applications/database-observability/configure/tune-alloy-collection/) has a high-volume example of those same settings.
