title: "Prerequisites | Grafana Labs"
description: "What you need to follow the journey's hands-on paths"
# For hands-on exercises
Both approaches need a free Grafana Cloud account ([sign up free](/signup/cloud/connect-account)) and Grafana Alloy, which collects data and sends it to Grafana Cloud. What you need beyond that depends on which approach you’re setting up.
## Database integration requirements
For a database integration you need a running instance of a supported database: MongoDB, Redis, Memcached, Cassandra, Oracle, MySQL, or PostgreSQL. You configure an exporter for that database as part of setup.
## Database Observability version requirements
For Database Observability, you need:
- A running MySQL 8.0 or later or PostgreSQL 14 or later database
- A database user with monitoring privileges
- Versions shown in the following table
| Requirement       | Details        |
| **Grafana Alloy** | Version 1.17.0 or later        |
| **MySQL**         | Version 8.0 or later (MySQL 5.7 and MariaDB aren’t supported)                                     |
| **PostgreSQL**    | Version 14 or later, with the `pg_stat_statements` extension enabled in each database you monitor |
Database Observability is available on the Grafana Cloud free tier and needs the Editor or Admin role. It is billed as a per-host hourly fee for each connected database, plus metrics and logs usage. On the free tier, metrics and logs, including query samples, are retained for 14 days. See [Database Observability pricing](/docs/grafana-cloud/platform/pricing-and-usage/database-observability/).
The monitoring user needs two kinds of access. Query statistics need the base privileges: for MySQL, `PROCESS`, `REPLICATION CLIENT`, and `SELECT` on `performance_schema`; for PostgreSQL, the `pg_monitor` and `pg_read_all_stats` roles. Schema details and explain plans also need access to the tables you want to see. Grant `SELECT` and `SHOW VIEW` on each MySQL schema you monitor, or on all schemas if you want every schema. For PostgreSQL, grant `USAGE` on each schema and `SELECT` on all tables in that schema, or grant `pg_read_all_data` if you want every object.
If you’re running MySQL 5.7, MariaDB, or an older PostgreSQL version, Database Observability isn’t available for those.
A [database integration](/docs/learning-hub/intro-to-integrations/) can still monitor the database instance’s overall health, such as connections, throughput, and replication status. However, that’s a different capability, not a substitute. An integration reports aggregate, instance-level metrics, not the per-query explain plans, wait events, and query samples that Database Observability provides.
## Recommended prior knowledge
| Topic                           | Why it helps                                               |
| Basic Grafana navigation        | You’ll use dashboards and the Configuration page.          |
| Terminal or command line basics | Alloy installation uses the CLI.                           |
| Basic database administration   | You’ll create a monitoring user and configure permissions. |
**Just exploring?** You can complete the journey without hands-on practice. The concepts are valuable on their own.
