You’re set up to work with data sources
You can choose a data source, connect it with a guided path, and put it to work by querying, visualizing, and alerting on your data where it already lives. Here’s where to go next.
Documentation
Learn more about connecting and using data sources:
Blog posts
See data sources in action:
- Grafana for beginners: Quick tips to add a data source, choose a visualization, and more
- How to work with multiple data sources in Grafana dashboards: best practices to get started
- Data sources, visualizations, and apps: A guide to extending and customizing Grafana
- Infinity plugin for Grafana: Grafana Labs will now maintain the versatile data source plugin
- Visualize Google Cloud BigQuery data in Grafana: the latest updates, key features, and more
Community
Connect with other Grafana users:
Continue learning
Here are additional resources to continue learning:
