Build a dashboard
After a query returns the data you want, turn it into a panel. A dashboard is a set of panels, and each panel runs a query against a data source and visualizes the result.
Tip: Before you build a panel, confirm the data source is returning data. Open it in Explore to run a quick query, no dashboard required.
Now try building one yourself. This hands-on path walks you through turning a query into a time series panel in a dashboard. Some data sources, like CloudWatch, also include prebuilt dashboards you can import, so you won’t always have to start from scratch.
Visualize metrics
Welcome to the Grafana learning path that shows you how to visualize CPU metrics in a dashboard.
Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
