How it works
One plugin gives you Azure metrics, Log Analytics workspaces, Application Insights, and Azure Resource Graph. Authenticate with a service principal, a managed identity when you run Grafana in Azure, or a Microsoft Entra ID app registration. Logs use KQL. Multi-subscription support lets you build dashboards that span your Azure estate.
What you get
- Metrics and Log Analytics in one plugin
- Application Insights integration
- Resource graph for discovery
- Multi-subscription support
- Template variables
Considerations
- KQL query learning curve
- Azure API latency
- Alert evaluation calls the API
Authentication options
Service principal, managed identity, or Microsoft Entra ID app registration
Documentation
View the Azure Monitor data source documentation.
