Section 4 · Query with data sources
Query Azure Monitor with a Grafana data source.
Estimated time: 1 min
Azure Monitor data source
Azure Monitor data source: Query metrics, Log Analytics, and App Insights from Grafana
One plugin gives you Azure metrics, Log Analytics workspaces, Application Insights, and Azure Resource Graph. In Grafana Cloud, authenticate with a Microsoft Entra ID app registration (a service principal). Managed identity and workload identity are only for Grafana you host in Azure. Logs use KQL (Kusto Query Language); a logs query builder is also available. Multi-subscription support lets you build dashboards that span your Azure estate.
What you get
  • Metrics and Log Analytics in one plugin
  • Application Insights integration
  • Resource graph for discovery
  • Multi-subscription support
  • Template variables
Considerations
  • KQL, or the logs query builder, for log queries
  • Azure API latency
  • Alert evaluation calls the API
Documentation
View the Azure Monitor data source documentation.
