title: "Azure Monitor data source | Grafana Labs"
description: "Query Azure Monitor with a Grafana data source."
# Azure Monitor data source
[![Azure Monitor data source: Query metrics, Log Analytics, and App Insights from Grafana](cp-olly-azure-monitor-ds-light.svg)](cp-olly-azure-monitor-ds-light.svg "Azure Monitor data source: Query metrics, Log Analytics, and App Insights from Grafana")
One plugin gives you Azure metrics, Log Analytics workspaces, Application Insights, and Azure Resource Graph. In Grafana Cloud, authenticate with a Microsoft Entra ID app registration (a service principal). Managed identity and workload identity are only for Grafana you host in Azure. Logs use KQL (Kusto Query Language); a logs query builder is also available. Multi-subscription support lets you build dashboards that span your Azure estate.
## What you get
- Metrics and Log Analytics in one plugin
- Application Insights integration
- Resource graph for discovery
- Multi-subscription support
- Template variables
## Considerations
- KQL, or the logs query builder, for log queries
- Azure API latency
- Alert evaluation calls the API
## Documentation
View the [Azure Monitor data source](/docs/grafana/latest/datasources/azure-monitor/) documentation.
