title: "AWS CloudWatch data source | Grafana Labs"
description: "Query AWS CloudWatch with a Grafana data source."
# AWS CloudWatch data source
[![AWS CloudWatch data source: Query CloudWatch metrics and logs directly from Grafana](cp-olly-aws-cloudwatch-ds-light.svg)](cp-olly-aws-cloudwatch-ds-light.svg "AWS CloudWatch data source: Query CloudWatch metrics and logs directly from Grafana")
Provide IAM credentials: access keys, an assumed role, or, in Grafana Cloud, **Grafana Assume Role**, which uses an IAM role that trusts Grafana’s AWS account. Once connected, you can query both metrics and logs. Build a dashboard that shows EC2 CPU, Lambda invocations, and RDS connections together, all pulling live from CloudWatch. Cross-account observability uses CloudWatch’s monitoring-account feature; alternatively, configure one data source per account.
## What you get
- Metrics and logs in one source
- Cross-account and cross-region
- Metric math and statistics
- Template variables
- Logs Insights queries
## Considerations
- CloudWatch API costs per query
- CloudWatch query language
- API latency affects dashboards
- Rate limits with many panels
- Alert evaluation calls the API. A query that times out returns an error
- Private resources are reached from Grafana Cloud with Private data source connect
## Documentation
View the [CloudWatch data source](/docs/grafana-cloud/connect-externally-hosted/data-sources/aws-cloudwatch/) documentation.
