title: "AWS metrics - Metric Streams | Grafana Labs"
description: "Collect AWS CloudWatch metrics using metric streams for low latency."
## How it works
[AWS Metric Streams architecture: AWS pushes metrics to Grafana Cloud via Kinesis Firehose](cp-olly-aws-metric-streams-light.svg "AWS Metric Streams architecture: AWS pushes metrics to Grafana Cloud via Kinesis Firehose")
**Recommended for AWS production**
**Complexity:** Moderate | **Infrastructure:** Firehose + IAM | **Latency:** Seconds
## Trade-offs
| Pros                         | Cons                        |
| Near real-time (seconds)     | Requires AWS infrastructure |
| Better cost profile at scale | More complex initial setup  |
| No API rate limits           |                             |
| Easier long-term maintenance |                             |
## Why metric streams for production
- Lower latency for alerting (seconds vs. minutes)
- Better cost profile as you scale
- Easier maintenance (no scrape schedules to manage)
- Scales smoothly across multi-account AWS
## Documentation
View the full documentation. *Learning path coming soon!*
[AWS metric streams](https://grafana.com/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/aws/cloudwatch-metrics/metric-streams/)
