title: "AWS metrics scrape jobs | Grafana Labs"
description: "Collect AWS CloudWatch metrics using scrape jobs."
## How it works
[AWS scrape jobs architecture: Grafana Cloud pulls metrics from CloudWatch API](cp-olly-aws-scrape-jobs-light.svg "AWS scrape jobs architecture: Grafana Cloud pulls metrics from CloudWatch API")
**Complexity:** Simple | **Infrastructure:** None | **Latency:** Minutes
## Trade-offs
| Pros                          | Cons                          |
| Configure in Grafana Cloud UI | 1-5 minute latency            |
| No AWS infrastructure needed  | CloudWatch API costs          |
| Covers 60+ AWS services       | API rate limits at scale      |
| Automatic service discovery   | Cross-account needs IAM setup |
| Converts to PromQL            |                               |
## When to use
- Quick start and evaluation
- Proof-of-concept setups
- Small environments with moderate metric volume
> **For production:** Consider [metric streams](/docs/learning-hub/intro-to-cp-olly/01-cloud-metrics/10-aws-metrics-metric-streams/) for better cost profile, lower latency, and easier maintenance.
## Learning path
Configure this approach step by step.
[AWS metrics scrape jobs](/docs/learning-hub/intro-to-cp-olly/01-cloud-metrics/16-aws-journey/)
