Section 2 · Cloud metrics
Collect AWS CloudWatch metrics using scrape jobs.
Estimated time: 1 min
How it works
AWS scrape jobs architecture: Grafana Cloud pulls metrics from CloudWatch API
Complexity: Simple | Infrastructure: None | Latency: Minutes
Configure an AWS integration in the Grafana Cloud UI and provide IAM credentials, typically a read-only user or role. Choose which regions and CloudWatch namespaces to scrape, such as EC2, RDS, or Lambda. Grafana Cloud queries the CloudWatch API on a schedule, pulls the metrics in, and converts them to Prometheus format so you can query them with PromQL.
Considerations
  • Configured entirely in the Grafana Cloud UI, with no AWS infrastructure to deploy
  • 60+ AWS services with automatic service discovery
  • Metrics in Prometheus format for PromQL
  • 1-5 minute latency
  • CloudWatch API cost and rate limits at scale
  • IAM setup for cross-account access
When to use
  • Quick start and evaluation
  • Proof-of-concept setups
  • Small environments with moderate metric volume
For ongoing production monitoring: See metric streams.
Path
Configure this approach step by step.
AWS metrics scrape jobs
