title: "AWS metrics scrape jobs | Grafana Labs"
description: "Collect AWS CloudWatch metrics using scrape jobs."
## How it works
[AWS scrape jobs architecture: Grafana Cloud pulls metrics from CloudWatch API](cp-olly-aws-scrape-jobs-light.svg "AWS scrape jobs architecture: Grafana Cloud pulls metrics from CloudWatch API")
**Complexity:** Simple | **Infrastructure:** None | **Latency:** Minutes
Configure an AWS integration in the Grafana Cloud UI and provide IAM credentials, typically a read-only user or role. Choose which regions and CloudWatch namespaces to scrape, such as EC2, RDS, or Lambda. Grafana Cloud queries the CloudWatch API on a schedule, pulls the metrics in, and converts them to Prometheus format so you can query them with PromQL.
## Considerations
- Configured entirely in the Grafana Cloud UI, with no AWS infrastructure to deploy
- 60+ AWS services with automatic service discovery
- Metrics in Prometheus format for PromQL
- 1-5 minute latency
- CloudWatch API cost and rate limits at scale
- IAM setup for cross-account access
## When to use
- Quick start and evaluation
- Proof-of-concept setups
- Small environments with moderate metric volume
> **For ongoing production monitoring:** See [metric streams](/docs/learning-hub/intro-to-cp-olly/01-cloud-metrics/08-aws-metrics-metric-streams/).
## Learning path
Configure this approach step by step.
[AWS metrics scrape jobs](/docs/learning-hub/intro-to-cp-olly/01-cloud-metrics/13-aws-journey/)
