Section 2 · Create your first watcher
Recalibrate after service changes, let Assistant review the checks on a schedule, restore an earlier version, and track token usage.
Estimated time: 2 min
Keep your watcher current
Your service keeps changing after you create a watcher, through new releases, new traffic, and new kinds of expected errors. Calibrated checks are read-only, so when they stop matching your service, you recalibrate the watcher.
Recalibrate after a change
After service changes or repeated noisy findings, click Recalibrate at the top of the watcher’s page, or Suggest a change on the Calibration tab. Optionally describe the change in What would you like to change?, for example to ignore brief latency spikes during deployments, and click Start recalibration.
Recalibration pauses scanning, keeps the issues the watcher is tracking, and starts monitoring again when it succeeds.
Let Assistant review the checks on a schedule
To have Assistant review and update the checks for you, open the Configuration tab, turn on Automatically update checks under Automatic actions, and choose a Review frequency.
Reviews run in the background without pausing scanning, and they keep your goal, data sources, schedule, and notifications. A review can finish without changing anything. Reviews run only while the watcher is Active.
Restore an earlier version
Calibration and automatic review changes are saved as versions on the Versions tab. If a change makes the watcher less useful, expand an earlier version to compare it, click Restore, and confirm with Restore watcher. Review the restored checks, then turn scheduled scanning back on with the switch at the top of the page.
Track token usage
Watcher runs, calibration, and automatic reviews use tokens from your Grafana Assistant plan’s monthly allowance. The Token usage card on the watcher’s Overview tab estimates its monthly usage at the current schedule. The usage meter on the Watchers list shows how much of the monthly limit your watchers have used and when it resets. If you reach the limit, runs and calibration stop until the reset, and scheduled watchers resume automatically.
