Section 2 · Create your first watcher
Each completed run gets an assessment, from no concerns to a critical concern.
Estimated time: 1 min
What a result means
When you run the checkout watcher, each completed run gets an assessment. The Watchers list shows the latest one, so you can tell whether checkout needs attention before you open the report.
LabelMeaning
All clearThe latest completed run found no concerns.
FlaggedThe latest completed run found a warning-level concern.
EscalatedThe latest completed run found a critical concern.
No verdict yetNo reliable assessment is available yet.
Checks failingThe latest finished run failed.
The hands-on learning path has you trigger a run and read this assessment.
