Create a watcher path
In this path, you create a watcher for a service that has live data, follow calibration as it saves checks, trigger Run now, and read the run’s report on the Run history tab. You end with a calibrated watcher scanning on its schedule, which you can pause or archive afterward.
Learning path
Get started with Assistant Watchers
Create a watcher, calibrate checks against your telemetry, run it, and review the first result.
13 min
Intermediate
Docs & blog posts
Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
