title: "Create a watcher path | Grafana Labs"
description: "Hands-on path to create a watcher, follow calibration, trigger a run, and review the result."
# Create a watcher path
In this path, you create a watcher for a service that has live data, follow calibration as it saves checks, trigger **Run now**, and read the run’s report on the **Run history** tab. You end with a calibrated watcher scanning on its schedule, which you can pause or archive afterward.
Learning path
#### Get started with Assistant Watchers
Create a watcher, calibrate checks against your telemetry, run it, and review the first result.
13 min
Intermediate
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud](https://grafana.com/docs/learning-hub/intro-to-assistant-watchers/02-create-a-watcher/08-create-watcher-path/)
[View on website](https://grafana.com/docs/learning-paths/intro-to-assistant-watchers/)
