Section 3 · Components and pipelines
Reading a simple pipeline as discover, collect, and send
Estimated time: 2 min
A pipeline in action
Here is a small pipeline that collects logs from files and writes them to Loki, a Grafana backend for log storage. This example focuses on the shape of the pipeline, not the syntax details, which come later in this journey.
This configuration comes from the runnable logs-file example in the alloy-scenarios repository.
Alloy
local.file_match "local_files" {
  path_targets = [{"__path__" = "/temp/logs/*.log", "job" = "python"}]
  sync_period  = "5s"
loki.source.file "log_scrape" {
  targets       = local.file_match.local_files.targets
  forward_to    = [loki.write.local.receiver]
  tail_from_end = true
loki.write "local" {
  endpoint {
    url = "http://loki:3100/loki/api/v1/push"
Read it as discover, collect, send
This short path uses discovery to start collecting, then sends the data on. It skips the transform job. Processing components often sit between collect and send in fuller pipelines.
Follow the data from top to bottom, from discovering log files through to sending entries to Loki.
local.file_match discovers files, loki.source.file collects them, loki.write sends the entries, and the entries arrive in Loki.
  • Discover: local.file_match finds matching log files.
  • Collect: loki.source.file tails those files and forwards the log entries.
  • Send: loki.write sends the entries to Loki.
Each component hands its work to the next, so the three components together form one pipeline.
Real pipelines do more
This example keeps the path short. Real production pipelines often add processing components between the collect and send steps to add or change identifying fields, parse log lines, filter unwanted data, or redact secrets.
