title: "When traces or metrics don't arrive | Grafana Labs"
description: "The export setup this route depends on when your generation is in Conversations but no span or metric from the SDK has reached Traces or Metrics."
# When traces or metrics don’t arrive
Your generation is in **Conversations**, but no span or metric from the SDK has reached your Grafana Cloud Traces or Metrics data source. These are the export setup facts this route depends on.
## The export setup
Each one is a value you set while exporting metrics and traces.
- **Providers are configured before the client.** Your application must configure a `TracerProvider` and `MeterProvider` before creating the Agent Observability client. Without them, SDK-emitted metrics and traces are dropped.
- **The Base64 header has no trailing newline.** `base64` adds a trailing newline that invalidates the header, so the `tr -d '\n'` in the command is not optional.
- **Use the OTLP Instance ID.** The Base64 value encodes the **Instance ID** from the **OpenTelemetry** card, which can differ from the Agent Observability Instance ID.
- **Your token covers the OTLP scopes.** The access policy token already covers the OTLP scopes if you selected them when you created the access policy.
