title: "Export metrics and traces | Grafana Labs"
description: "Complete the seventh milestone of the Connect an agent to Agent Observability learning path."
# Export metrics and traces
Go back to the Grafana Cloud tab where you opened the learning path and complete Milestone 7, then return here. If you closed that tab, open the path again from the card below. When you rerun your agent, check your Grafana Cloud **Traces** and **Metrics** data sources for SDK-emitted spans and metrics.
Learning path
#### Connect an agent to Agent Observability
Enable Agent Observability on a Grafana Cloud stack, authenticate the SDK, capture your agent's first generation, find it in Conversations, and export its traces and metrics.
18 min
Beginner
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud](https://grafana.com/docs/learning-hub/intro-to-agent-observability/07-add-traces-and-metrics/34-export-traces-and-metrics/)
[View on website](https://grafana.com/docs/learning-paths/connect-agent-to-agent-observability/)
## When you finish
Your Grafana Cloud **Traces** and **Metrics** data sources now have SDK-emitted spans and metrics.
