title: "Direct export or a collector | Grafana Labs"
description: "The two ways to send OTLP data to Grafana Cloud: directly to the OTLP gateway, or through a local Grafana Alloy or OpenTelemetry Collector."
# Direct export or a collector
The hands-on exercise in this section sends OTLP data directly to the Grafana Cloud OTLP gateway. The other route, a local Grafana Alloy or OpenTelemetry Collector, is covered below so you recognize it later.
[![In direct export, your application holds the credentials and exports OTLP data to the Grafana Cloud OTLP gateway. With a collector, your application exports unauthenticated OTLP to http://localhost:4318, and Grafana Alloy or the OpenTelemetry Collector receives it and forwards it to Grafana Cloud with credentials.](https://grafana.com/docs/learning-hub/intro-to-agent-observability/07-add-traces-and-metrics/32-direct-export-or-a-collector/direct-export-or-a-collector.svg)](https://grafana.com/docs/learning-hub/intro-to-agent-observability/07-add-traces-and-metrics/32-direct-export-or-a-collector/direct-export-or-a-collector.svg "In direct export, your application holds the credentials and exports OTLP data to the Grafana Cloud OTLP gateway. With a collector, your application exports unauthenticated OTLP to http://localhost:4318, and Grafana Alloy or the OpenTelemetry Collector receives it and forwards it to Grafana Cloud with credentials.")
## Direct export
With direct export, no collector needed. The OTLP endpoint and optional auth headers are set through environment variables. In the hands-on exercise you set two:
- **`OTEL_EXPORTER_OTLP_ENDPOINT`:** the endpoint URL from the **OpenTelemetry** card, including `/otlp` but excluding paths such as `/v1/traces`.
- **`OTEL_EXPORTER_OTLP_HEADERS`:** `Authorization=Basic <BASE64_CREDENTIALS>`, with a plain space after `Basic`, where `<BASE64_CREDENTIALS>` is the Base64-encoded OTLP instance ID and access policy token.
> Note
> Python exporters older than `opentelemetry-exporter-otlp-proto-http` 1.27.0 reject the space and log `Header format invalid`. On one of those, upgrade the exporter or write `Basic%20<BASE64_CREDENTIALS>` instead.
The documented command prints `<OTLP_INSTANCE_ID>:<ACCESS_POLICY_TOKEN>`, pipes it through `base64`, then through `tr -d '\n'`.
> Warning
> The `tr -d '\n'` is not optional. `base64` adds a trailing newline that invalidates the header.
Base64, which is a standard encoding that turns the `instance-id:token` pair into one string the header can carry, is not encryption. Keep the encoded value as secret as the token.
## A collector
A local Grafana Alloy or OpenTelemetry Collector receives unauthenticated OTLP from your application and forwards it to Grafana Cloud with credentials. Your application then points `OTEL_EXPORTER_OTLP_ENDPOINT` at `http://localhost:4318` instead of the gateway, and you can skip the OpenTelemetry card.
A collector gives you centralized token management, retries, relabeling, and metadata enrichment, at the cost of running another process. **Relabeling**, which is changing or dropping labels on your metrics and traces before they are stored, and **metadata enrichment**, which is adding fields such as the host or environment, both happen in the collector. For how Alloy does each one, refer to [otelcol.processor.attributes](https://grafana.com/docs/alloy/latest/reference/components/otelcol/otelcol.processor.attributes/) for relabeling and [otelcol.processor.resourcedetection](https://grafana.com/docs/alloy/latest/reference/components/otelcol/otelcol.processor.resourcedetection/) for metadata enrichment. This journey does not set up a collector.
> Note
> With this SDK setup, Alloy or the Collector forwards metrics and traces only. Generation data goes directly to the Agent Observability API.
