title: "Two Instance IDs | Grafana Labs"
description: "The OTLP endpoint URL and OTLP instance ID on the OpenTelemetry card, why that Instance ID can differ from the Agent Observability one, and why not to generate a second token."
# Two Instance IDs
To send OpenTelemetry metrics and traces directly to Grafana Cloud, you also need an OTLP endpoint URL and an OTLP instance ID.
- The **OTLP endpoint URL**, the address OpenTelemetry exporters send metrics and traces to. It is the value for `OTEL_EXPORTER_OTLP_ENDPOINT`.
- The **OTLP Instance ID**. An Instance ID is a numeric Grafana Cloud stack ID. This one is the **basic auth** username for OTLP. Basic auth uses a username and a secret: this Instance ID is the username, and the access policy token is the secret.
## How to locate the OTLP endpoint URL and Instance ID
The page at `https://grafana.com/orgs/<org>/stacks/<stack-id>` shows a card for each product on your stack, and each card contains information about that product. The **OpenTelemetry** card shows the OTLP endpoint URL and the Instance ID.
## The two Instance IDs can differ
The Instance ID on the OpenTelemetry card is not necessarily the same as the Agent Observability **Instance ID** you copied from the setup screen and use as `AGENTO11Y_AUTH_TENANT_ID`.
[![The Instance ID on the setup screen in Agent Observability is a numeric stack ID used as AGENTO11Y_AUTH_TENANT_ID. The Instance ID on the OpenTelemetry card on the Grafana Cloud portal is the basic auth username for OTLP.](https://grafana.com/docs/learning-hub/intro-to-agent-observability/07-add-traces-and-metrics/31-two-instance-ids/two-instance-ids.svg)](https://grafana.com/docs/learning-hub/intro-to-agent-observability/07-add-traces-and-metrics/31-two-instance-ids/two-instance-ids.svg "The Instance ID on the setup screen in Agent Observability is a numeric stack ID used as AGENTO11Y_AUTH_TENANT_ID. The Instance ID on the OpenTelemetry card on the Grafana Cloud portal is the basic auth username for OTLP.")
> Caution
> Use the number shown on the card for OTLP.
## Why not to generate a second token
The access policy token already covers the OTLP scopes because you selected `metrics:write`, `logs:write`, and `traces:write` when you created the access policy.
> Caution
> Don’t click **Generate now** on the OpenTelemetry card.
