If the generation does not appear
Your first generation should appear in Conversations within a few seconds of running your instrumented agent. If it has not, review these settings.
The setup
Each one is a setting you made while connecting the SDK.
- The variables were set before you created the client. The SDK reads them at client construction only.
AGENTO11Y_AUTH_MODEisbasic.AGENTO11Y_AUTH_TENANT_IDandAGENTO11Y_AUTH_TOKENhold the Instance ID and the token you copied.- Your code shut down the client. As in the capture sample,
client.shutdown()runs last.
