title: "If the generation does not appear | Grafana Labs"
description: "Review the settings you made while connecting the SDK if your generation does not appear in Conversations within a few seconds."
# If the generation does not appear
Your first generation should appear in **Conversations** within a few seconds of running your instrumented agent. If it has not, review these settings.
## The setup
Each one is a setting you made while connecting the SDK.
- **The variables were set before you created the client.** The SDK reads them at client construction only.
- **`AGENTO11Y_AUTH_MODE` is `basic`.**
- **`AGENTO11Y_AUTH_TENANT_ID` and `AGENTO11Y_AUTH_TOKEN` hold the Instance ID and the token you copied.**
- **Your code shut down the client.** As in the capture sample, `client.shutdown()` runs last.
