Why traces and metrics need more setup
The Agent Observability SDK sends generation data to the Agent Observability API. Your generation is in Conversations in Agent Observability. The metrics and traces it emits are separate from generation data.
A TracerProvider and a MeterProvider are part of the OTel SDK. Without them configured in your application, those metrics and traces go to the default no-op, a provider that does nothing with them, and are dropped. The Agent Observability SDK does not create that setup. Your application must set it up.
