title: "Why traces and metrics need more setup | Grafana Labs"
description: "Why your generation is in Conversations while the Traces and Metrics data sources have nothing from the SDK yet."
# Why traces and metrics need more setup
The Agent Observability SDK sends generation data to the Agent Observability API. Your generation is in **Conversations** in Agent Observability. The metrics and traces it emits are separate from generation data.
A `TracerProvider` and a `MeterProvider` are part of the OTel SDK. Without them configured in your application, those metrics and traces go to the default no-op, a provider that does nothing with them, and are dropped. The Agent Observability SDK does not create that setup. Your application must set it up.
[![Inside your application, the Agent Observability SDK sends generation data to the Agent Observability API, and the generation is in Conversations in Agent Observability. Metrics and traces leave the SDK on a dashed path that forks into two branches. The branch toward the OTel SDK, whose TracerProvider and MeterProvider are not configured, is blocked. The other branch goes to the default no-op, and from there to dropped.](https://grafana.com/docs/learning-hub/intro-to-agent-observability/06-see-your-first-conversation/27-why-traces-and-metrics-need-more-setup/generation-arrived-metrics-dropped.svg)](https://grafana.com/docs/learning-hub/intro-to-agent-observability/06-see-your-first-conversation/27-why-traces-and-metrics-need-more-setup/generation-arrived-metrics-dropped.svg "Inside your application, the Agent Observability SDK sends generation data to the Agent Observability API, and the generation is in Conversations in Agent Observability. Metrics and traces leave the SDK on a dashed path that forks into two branches. The branch toward the OTel SDK, whose TracerProvider and MeterProvider are not configured, is blocked. The other branch goes to the default no-op, and from there to dropped.")
