Section 5 · Capture your first generation
Complete the fifth milestone of the Connect an agent to Agent Observability learning path.
Estimated time: 1 min
Install the SDK and capture a generation
Go back to the Grafana Cloud tab where you opened the learning path and complete Milestone 5, then return here. If you closed that tab, open the path again from the card below.
Learning path
Enable Agent Observability on a Grafana Cloud stack, authenticate the SDK, capture your agent's first generation, find it in Conversations, and export its traces and metrics.
18 min
Beginner
Docs & blog posts
Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
When you finish
You installed the SDK for your language and captured your first generation.
