Why you need a token
You need three values to send conversation data: an Agent Observability endpoint URL, an instance ID, and a Grafana Cloud Access Policy Token, a credential from Grafana Cloud. The token is the one value you do not have yet.
What authentication decides
Agent Observability enforces tenant isolation so each tenant’s data is fully separated from the data of other tenants. The SDK auth configuration determines which tenant your data belongs to. In basic mode:
tenantIdis your Grafana Cloud instance ID.basicPasswordis your Grafana Cloud Access Policy Token.
What the token adds
The token is the actual secret used to authenticate an action. Token permissions are controlled by the access policy they belong to.
Warning
The token is shown only once, so copy it when it appears.
