title: "Why you need a token | Grafana Labs"
description: "The credential you still need, and what authentication decides together with the instance ID."
# Why you need a token
You need three values to send conversation data: an Agent Observability endpoint URL, an instance ID, and a **Grafana Cloud Access Policy Token**, a credential from Grafana Cloud. The token is the one value you do not have yet.
## What authentication decides
Agent Observability enforces **tenant isolation** so each tenant’s data is fully separated from the data of other tenants. The SDK auth configuration determines which tenant your data belongs to. In `basic` mode:
- `tenantId` is your Grafana Cloud instance ID.
- `basicPassword` is your Grafana Cloud Access Policy Token.
## What the token adds
The token is the actual secret used to authenticate an action. Token permissions are controlled by the access policy they belong to.
> Warning
> The token is shown only once, so copy it when it appears.
