Enable Agent Observability and copy its values
Open the learning path in Grafana Cloud and complete Milestones 1 and 2, then return here. Keep that Grafana Cloud tab open: you continue the path there later.
Learning path
Connect an agent to Agent Observability
Enable Agent Observability on a Grafana Cloud stack, authenticate the SDK, capture your agent's first generation, find it in Conversations, and export its traces and metrics.
18 min
Beginner
Docs & blog posts
Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
When you finish
Agent Observability is enabled on your stack, and you have copied API URL and Instance ID from the setup screen.
