title: "Enable Agent Observability and copy its values | Grafana Labs"
description: "Complete the first two milestones of the Connect an agent to Agent Observability learning path."
# Enable Agent Observability and copy its values
Open the learning path in Grafana Cloud and complete Milestones 1 and 2, then return here. Keep that Grafana Cloud tab open: you continue the path there later.
Learning path
#### Connect an agent to Agent Observability
Enable Agent Observability on a Grafana Cloud stack, authenticate the SDK, capture your agent's first generation, find it in Conversations, and export its traces and metrics.
18 min
Beginner
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud](https://grafana.com/docs/learning-hub/intro-to-agent-observability/03-enable-agent-observability/11-enable-and-copy-values/)
[View on website](https://grafana.com/docs/learning-paths/connect-agent-to-agent-observability/)
## When you finish
Agent Observability is enabled on your stack, and you have copied **API URL** and **Instance ID** from the setup screen.
