title: "What enabling does | Grafana Labs"
description: "Who enables Agent Observability, what changes on your stack after you save, and how the product is billed."
# What enabling does
An administrator must enable Agent Observability for your stack. To enable it, you sign in to Grafana Cloud as an administrator, review and accept the terms, and click **Save**.
## What changes after you save
After you enable Agent Observability:
- **Agent Observability** is available under **Observability** in the left sidebar.
- `sigil:write`, which is the write permission the SDK’s token needs, appears in the scope list when you create the access policy the token belongs to.
## How it is billed
Enabling Agent Observability does not start billing. Agent Observability is billed on usage, and a generation is counted each time your application calls an LLM provider and the SDK exports that interaction. For the pricing model, refer to [Agent Observability pricing](https://grafana.com/docs/grafana-cloud/platform/pricing-and-usage/agent-observability/).
> Tip
> To review Agent Observability usage alongside the rest of your Grafana Cloud spend, go to **Cost Management and Billing** &gt; **Usage** in your stack.
