The investigation workflow
A typical investigation moves through five steps. You can skip a step or go back.
Related metrics lists other metrics with similar names and common prefixes. Related logs shows how many related log lines match the metric so you can continue in a logs workflow.
Copy URL copies the current page address. It is not stored in the app. Add bookmark saves the data source, filters, selected metric, label breakdowns, and time range in this browser only. Bookmarks are not synced across browsers or devices. To share a view with someone else, use Copy URL.
A Query results tab can also appear when your Grafana instance includes the Prometheus query results component. It shows the raw query results for the metric.
