Section 2 · Metrics Drilldown
Queryless browsing for Prometheus-compatible metrics
Estimated time: 1 min
What is Grafana Metrics Drilldown?
Grafana Metrics Drilldown is a queryless way to browse Prometheus-compatible metrics. You can find related metrics and look at them without writing PromQL.
From the Grafana menu, select Drilldown > Metrics. Choose a Prometheus or Prometheus-compatible data source.
How it works
Metrics Drilldown lets you segment metrics by their labels:
  • See the metrics in the selected data source
  • Filter with Add label (a label name, an operator, and a value), or type keywords in the metric search bar
  • See a visualization chosen for the metric type, such as a gauge or a counter, without setting that up yourself
  • Open Related metrics for other metrics with similar names, and Related logs for a count of log lines that match the metric
