What you need
Your pipeline must authenticate to Grafana without exposing credentials in code. GitHub Actions provides two mechanisms: secrets for sensitive values and variables for non-sensitive configuration. You need three values: one secret and two variables.
Add and reference your credentials
Store the three values in your repository, then reference them from your workflow.
- In your repository, go to Settings > Secrets and variables > Actions.
- On Repository secrets, add
GRAFANA_TOKENwith your service account token. Never commit this token to your repository. - On Repository variables, add
GRAFANA_SERVERandGRAFANA_STACK_ID. - Reference the secret with the
secretscontext and the variables with thevarscontext.
env:
GRAFANA_SERVER: ${{ vars.GRAFANA_SERVER }}
GRAFANA_STACK_ID: ${{ vars.GRAFANA_STACK_ID }}
GRAFANA_TOKEN: ${{ secrets.GRAFANA_TOKEN }}Authenticate Terraform
Pass authentication to the Terraform provider through environment variables or directly in the provider block. Set TF_VAR_grafana_url and TF_VAR_grafana_token as environment variables, and Terraform picks them up automatically. The environment variable approach keeps your Terraform code portable: the same configuration works locally and in CI.
provider "grafana" {
url = var.grafana_url
auth = var.grafana_token
