Section 4 · CI/CD automation
How the pieces fit together in a CI/CD pipeline
Estimated time: 1 min
CI/CD pipeline flow
This diagram shows the end-to-end pipeline from code commit to deployed dashboard.
Diagram showing CI/CD pipeline: on pull request, code flows through generate, plan, and PR comment stages; on merge to main, it continues through Terraform apply to a live dashboard in Grafana
What each stage does
The pipeline has three stages, each triggered at a different point in the workflow.
StageTriggerAction
GenerateEvery pushRun SDK code, produce dashboard JSON
PlanEvery pushShow what Terraform will change
ApplyMerge to main onlyDeploy changes to Grafana
When each path runs
The same stages run along two paths, depending on where the code is in the workflow:
  • On a pull request: the pipeline runs generate and plan, then posts the plan as a PR comment for review. Nothing is deployed yet.
  • On merge to main: the pipeline runs all three stages. Generate produces the latest JSON and Terraform applies it, so the dashboard in Grafana always reflects the latest code on main.
The review gate
The Terraform plan output is posted as a PR comment so you can see:
  • Which dashboards will be created, updated, or destroyed
  • Exactly what configuration will change
This gives you the full benefits of dashboards as code: every change is reviewed, every deployment is automated, and you can trace any dashboard back to the commit that produced it.
