Learning path: Deploy a dashboard with Terraform
Path: Deploy a dashboard with Terraform
The following table describes the steps you’ll work through in the path.
Before you start
Have these ready before you open the path:
- A Grafana Cloud account or self-managed Grafana instance (version 12 or higher)
- Terraform installed (version 1.0 or later)
- A dashboard JSON file (from the previous path or exported from the Grafana UI)
- Admin or Editor permissions on your Grafana instance
Learning path
Welcome to the learning path that shows you how to deploy SDK-generated dashboard JSON to Grafana using the Terraform provider.
14 min
Intermediate
Docs & blog posts
Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
