Deploy your dashboards
Now it’s time to connect your code-generated dashboards to a running Grafana instance.
Deployment methods available in Grafana
Grafana supports several ways to deploy dashboards from code. The right choice depends on the workflow your team already uses. Each has different trade-offs.
This journey covers Terraform deployments. You’ll produce as-code workflows that integrate with your existing infrastructure code.
